Parallella Community • View topic - epiphany 5 IO,
epiphany 5 IO,
epiphany 5 IO,
Postby dobkeratops » Tue Mar 14, 2017 8:31 am
dobkeratops
Re: epiphany 5 IO,
Postby sebraa » Tue Mar 14, 2017 8:07 pm
Re: epiphany 5 IO,
Postby olajep » Fri Mar 17, 2017 8:16 pm
Re: epiphany 5 IO,
Postby dobkeratops » Sat Mar 18, 2017 4:19 pm
dobkeratops
Re: epiphany 5 IO,
Postby sebraa » Tue Mar 21, 2017 1:05 pm
Having an SPI interface does not mean that it is active after power-up and able to fetch instructions (and to instruct a core to execute them afterwards).
Mikrocontrollers contain built-in flash or ROM storage, which either contains the firmware or all the code needed to load and execute the firmware.
If the eLink can be run sufficiently slow - I think it can - then you won't need an FPGA to bootstrap the Epiphany. But you'd still need a controller.
