Parallella Community • View topic - How to build a kernel on a Parallela board
Re: How to build a kernel on a Parallela board
Postby nickoppen » Tue May 27, 2014 2:00 am
Well, I don't know what happened last time. I suspect I skipped a step or two.
I took the whole process from the top and now it's good. Actually the sound is better than on my Windows box.
nick
nickoppen
Postby shodruk » Tue May 27, 2014 4:40 am
Postby shodruk » Thu Jun 19, 2014 12:12 pm
Postby Transcendental » Thu Jun 19, 2014 2:55 pm
Transcendental
Postby over9000 » Thu Jun 19, 2014 3:09 pm
over9000
Postby shodruk » Thu Jun 19, 2014 5:47 pm
Transcendental,
Thanks! I've read that. But audiophiles don't think so. (e.g. HD audio reduces jitter) It's like a ... review of art. :lol:
over9000,
Great! That's easy and useful.
Postby frank_buss » Fri Jun 20, 2014 1:18 am
shodruk, thanks for this manual, worked for me. But you should add "make modules" and "make modules_install" at the end, because there are some modules enabled in the default Parallella kernel configuration, and the "make modules_install" target creates the file "/lib/modules/3.12.0-parallella/build", which makes it easy to write your own loadable kernel modules, for example as explained here: http://www.thegeekstuff.com/2013/07/wri ... el-module/
frank_buss
Postby shodruk » Fri Jun 20, 2014 3:28 pm
Postby theover » Fri Jun 20, 2014 11:07 pm
I'm grateful for the easy to follow kernel recompile description, I just played my first audio from the Parallella over my self-made USB AD/DA convertor, from the network, and with a sample conversion. Now I'll look into Jack.
T.
Postby shodruk » Sat Jun 21, 2014 2:31 pm
Return to Linux/U-Boot
