Cannot boot after adding FPGA accelerator
Postby jimmystone » Sun May 21, 2017 9:14 am
Hi, All
I cannot boot my Parallella after I add my FPGA accelerator to the headless_e16_z7020 project
I am sure I can make my Parallella without this accelerator adding to my headless_e16_z7020 project when replacing parallella.bit.bin
The UART is printing this message again and again. I think the Parallella found something wrong and reboot.
Is there any special setting if I want to add some logic in the Zynq part?
Can anyone help? Thanks
Hit any key to stop autoboot:  0
Device: SDHCI
Manufacturer ID: 3
OEM: 5344
Tran Speed: 50000000
Rd Block Len: 512
SD version 2.0
High Capacity: Yes
Capacity: 3.7 GiB
Bus Width: 4-bit
reading parallella.bit.bin
4045568 bytes read
jimmystone
Re: Cannot boot after adding FPGA accelerator
Postby miguel_rodrigues » Mon May 22, 2017 7:29 am
If you simply replaced the provided FPGA bitstream with your own that doesn't implement the glue logic required for ARM <-> Epiphany communication, I believe that the error is expected. Or maybe it has to do with memory zones.
What were the exact steps you followed to add your accelerator after opening the Parallella Vivado project?
miguel_rodrigues
Postby jimmystone » Mon May 22, 2017 2:45 pm
miguel_rodrigues wrote:If you simply replaced the provided FPGA bitstream with your own that doesn't implement the glue logic required for ARM <-> Epiphany communication, I believe that the error is expected. Or maybe it has to do with memory zones.
I keep all the original logic in Parallella project. and Add an my accelerator as an IP to this project in the system.bd.
This IP use a new clock FCLK_CLK1, and connect ARM with UART0.
reset pin is connect like this: FCLK_RESET1_N ------ proc_sys_reset_1 ----- my IP rst pin
Then I save the system.bd file and wrote it to tcl with
write_bd_tcl -force system_bd.tcl
then ./build.sh again
BTW, I have test UART0 working correctly with its RX connect to TX in a loop test, device tree is updated, and FPGA/Linux seems work all right.
What I missing?
Thanks.
jimmystone
Postby sebraa » Tue May 23, 2017 7:23 am
Does your accelerator work if you replace the FPGA bitstream at runtime (dd if=bitstream.bit.bin of=/dev/xdevcfg)?
You need the Xilinx driver for doing so, so if you don't have it, you may need to build your own kernel.
Postby jimmystone » Wed May 31, 2017 12:31 pm
sebraa wrote:Does your accelerator work if you replace the FPGA bitstream at runtime (dd if=bitstream.bit.bin of=/dev/xdevcfg)?
I finally found out this maybe the root cause:
1. My accelerator works at 50MHz using FCLK1. (about 50MHz, there is timming issue for PL setup timing)
2. It seems FCLK1 is 200MHz when Linux booted
3. I try to simplify my accelerator, and it can boot to Linux, and I changed FCLK1 to 50MHz, it works fine.
I read the thread as reference https://parallella.org/forums/viewtopic.php?f=51&t=3443
My question now comes to
I think it is the timming issue in FPGA logic cause the ZYNQ boot fail.
Is there any way to configure FCLK1 before it loads the FPGA login into PL?
Thanks.
jimmystone
Postby sebraa » Wed May 31, 2017 5:03 pm
I always boot with the original Epiphany bitstream, and then replace the FPGA logic at runtime (writing it to /dev/xdevcfg). This way, I can check (or unload) the Epiphany driver before loading my accelerator, which avoids a crash (my bitstreams do not contain the eLink interface, so the Epiphany driver must not be loaded).
Loading at runtime seems to reconfigure the FCLK clock speed, although I haven't tested this to be sure.
Postby miguel_rodrigues » Thu Jun 01, 2017 7:29 am
I do also boot with the original bitstream and replace with my own at runtime. However, simply loading the bitstream won't change your FCLKs, you need to do it explicitly before replacing the bitstream with your own (like the thread you reference mentions).
To achieve what you want, I would also ask over at Xilinx forums as this is not a question specific to Parallella.
But if I were you, I would simply write a script that executed as soon as Linux finishes booting and replaces the original bitstream with your own and changes clocks accordingly. From what I gather, you would obtain equivalent functionality :)
miguel_rodrigues
Postby jimmystone » Sun Jun 04, 2017 4:26 am
Hi, All
Update status
I try to change the fclk3 freq to 50MHz with shell script
https://gist.github.com/Kirill888/24385a36697959924d78
Then I try to update PL at runtime with this cmd
parallella@parallella:~$ sudo dd if=myacc.fclk3_50MHz.uart0.bit.bin of=/dev/xdevcfg
The whole system seems reboot again
But if I try to configure the original PL img at runtime, with this cmd
parallella@parallella:~$ sudo dd if=parallella.bit.bin of=/dev/xdevcfg
7901+1 records in
7901+1 records out
4045568 bytes (4.0 MB) copied, 0.534912 s, 7.6 MB/s
It seems fine.
Any idea?
jimmystone
Postby jimmystone » Wed Jun 07, 2017 3:48 pm
Hi, All
Update!
I can make my accelerator work at fclk3=35MHz, If I setting fclk3 above this freq, system will reboot.
I think there maybe power issue on Parallella.
Is there any way make a better power for Parallella?
Thanks.
jimmystone
Postby olajep » Tue Jun 20, 2017 3:40 pm
jimmystone wrote:Hi, All
Update status
Weird. I'd expect the board to freeze if something was wrong with the new bitstream, not reboot.
What Parabuntu release are you using (2016.11 or 2016.3) ?
jimmystone wrote:But if I try to configure the original PL img at runtime, with this cmd
7901+1 records in
7901+1 records out
It seems fine.
Any idea?
Try removing the epiphany module before reconfiguring the FPGA
$ sudo rmmod epiphany
// Ola
