Parallella Community • View topic - how much would E5 have costed
Postby dobkeratops » Fri Mar 31, 2017 6:32 pm
http://wccftech.com/nvidia-geforce-gtx- ... gpu-specs/
so with mass market hardware, $200 approx gets you a card with 4tflops (4billion transistors), but thats 120watts .. not suitable for drones and so on
the 1024 core epiphany is at ~4billion transistors, that would also be 4tflops? (1024x2x2ghz perhaps) .. but I imagine consuming much less power for a problem that fits on chip
with sufficient volume, should it have been possible to get a 'parallela 2' into that sort of price range .. the ultimate device for drones etc
dobkeratops
Re: how much would E5 have costed
Postby jar » Fri Mar 31, 2017 8:12 pm
E5 is published to be 117 mm^2. Let's call that 9x13mm. If you use a wafer calculator to figure out many die candidates you can get per wafer, it's a little more than 500 on a 12" wafer. If the cost per wafer is $10,000, you end up with $20/E5. This is about the best case scenario and cannot go lower unless you run your own fab. It also doesn't count design, packaging, tapeout, masks, making a product, or profit. It's why it's often important to have a large market because those other costs can sometimes be large.
BTW, the 4 single precision TFLOPS number is based on 2 SP FMAs/clock at 1 GHz, not 2 GHz.
Do you happen to know anyone looking to make 100,000+ drones with 4 TFLOPS onboard?
Postby dobkeratops » Sat Apr 01, 2017 3:00 am
dobkeratops
Postby CRosenbauer » Sat Apr 01, 2017 3:22 am
CRosenbauer
Users browsing this forum: Google [Bot] and 0 guests
