Parallella Community • View topic - AXI Peripheral. Works in hdmi project but not in headless
Postby AndyC » Mon Sep 22, 2014 12:08 pm
Hi Guys,
I have managed to add AXI peripherals using XPS on the hdmi project and everything works fine.
When I do the same on the headless project though I get the following critical warnings:
[Constraints 18-11] Could not find cell or net 'axi_interconnect_1/*_converter_bank/*clock_conv_inst/*asyncfifo_*/*mem/*dout_i_???' [C:/Development/parallella/Fpga/parallella-hw/fpga/edk/parallella_7020_headless/implementation/system_axi_interconnect_1_wrapper.ncf:6]
[Constraints 18-11] Could not find cell or net 'axi_interconnect_1/*_converter_bank/*clock_conv_inst/*asyncfifo_*/*mem/*dout_i_????' [C:/Development/parallella/Fpga/parallella-hw/fpga/edk/parallella_7020_headless/implementation/system_axi_interconnect_1_wrapper.ncf:7]
If I run through the implementation and generate the bitstream it loads ok but when I try to read from the AXI bus from a linux app the parallella hangs totally, so I guess these warnings are important :)
I have been banging my head against the wall for a couple of days over this, does anyone have any pointers of where to look to find the problem?
Andy
AndyC
Re: AXI Peripheral. Works in hdmi project but not in headles
Postby yanidubin » Tue Sep 23, 2014 1:49 am
If you look in the Warnings tab in XPS, you probably get warnings of the sort:
WARNING:EDK:4059 - INSTANCE: processing_system7_0, Overriding connection of
PORT: M_AXI_GP1_RDATA, VALUE: processing_system7_0_M_AXI_GP1_RDATA - which is
part of the connected BUSIF: M_AXI_GP1 -
/stash/files/dev/embedded/parallella/parallella-fpga-tutorials/Tutorial001_AX
I4Lite/Tutorial001_AXI4Lite.srcs/sources_1/system/system.mhs line 115
I believe this is conflicting with the eLink.
I think I have confirmed my theory ( is the ref since this was cross-posted) from last night that the GP0/GP1 is your issue. For example, if you do a diff on the system.mhs for the headless and hdmi projects, you will notice that the hdmi IP core already uses GP0, so it is already enabled, and I guess XPS happens to stick the IPCore on this bus (by default)
parallella-hw$ diff fpga/edk/parallella_7020_{headless,hdmi}/system.mhs | grep M_AXI_GP0
> PARAMETER C_USE_M_AXI_GP0 = 1
> BUS_INTERFACE M_AXI_GP0 = axi_interconnect_1
> PORT M_AXI_GP0_ACLK = processing_system7_0_FCLK_CLK0_0
yanidubin
Postby AndyC » Tue Sep 23, 2014 6:51 am
Hi Yani,
Thanks very much for your help and pointers.
Well I have spent another couple of hours trying to get this to work and have failed in a variety of ways!
I think I will carry on using the hdmi project and wait for your tutorial on how to set up the headless project.
Cheers
Andu
AndyC
Postby yanidubin » Tue Sep 23, 2014 7:58 am
Hi Andy,
Sorry it took a while - you can find it at the new thread I've started for my tutorials so that questions/feedback can all be in the same place.
Hopefully that helps you. If not, (or anyway) I recommend diffing the whole system.mhs you have, and the one from my project here: https://github.com/yanidubin/parallella ... system.mhs.
I find it is often something like the clocks misbehaving. Indeed, I already had to redo the tutorial in a roundabout way as I discovered Xilinx didn't properly handle having the PCore added, then shifted to GP0 once that was avialable. It allowed the bus assignment, but wouldn't hook up the clock.
I am not a big fan of Xilinx today - I tried running through the (already workaround) steps today, and they kept inexplicably failing. By diffing the system.mhs I could see it was randomly deleting some of my clock definitions, but had no idea why. After some hours of frustration (it was so easy the first time!), I restarted XPS, and the same thing which had been failing suddenly behaved.
Anyways, I always refer to system.mhs when I want to see what the tool has really changed, or what differs between projects. I'm not really a UI guy myself, and it is times like this I feel justified hacking it by hand.
yanidubin
Postby AndyC » Tue Sep 23, 2014 8:57 am
Hi Yani,
I cannot see the tutorial 1 on the blog site, is it done yet?
I know what you mean by the Xilinx tools, I think I have been spoiled as a software developer. I pity people that have to use these tools for their job!
I will have another fumble and see how the mhs files differ...
Cheers
Andy
AndyC
Postby yanidubin » Tue Sep 23, 2014 9:01 am
*facepalm* Oh dear, I forgot to make it public. Try now :)
yanidubin
Postby AndyC » Tue Sep 23, 2014 9:07 am
Nice one thanks.
I can be your first tester :)
AndyC
Postby AndyC » Tue Sep 23, 2014 9:43 am
Hi Yani,
Ok I followed your example and hit one of the problems I have been getting.
When I go to set the bus for M_AXI_GP0 the only bus I can choose is axi_interconnect_0.
The only way around this is to add the IP core before doing this and then I get loads of other issues.
How do you get axi_interconnect_1 to appear before adding the ip core?
Cheers
Andy
AndyC
Postby yanidubin » Tue Sep 23, 2014 9:53 am
Interesting that you have an axi_interconnect_0 already. Is this a fresh system.mhs from the parallella-hw repo?
Well, you should get the options for existing interconnects (axi_interconnect_0 in your case), as well as "No Connection" and "New Connection". Do you get an option "New Connection"? If you choose that, I believe it will create axi_interconnect_1.
But actually the name of the interconnect is immaterial - I am not sure why you got 0, and I got 1 - maybe one of us did something a bit differently.
The only important thing is that you have an interconnect with both the correct master and the correct peripheral attached to it.
yanidubin
Postby AndyC » Tue Sep 23, 2014 10:04 am
Hi Yani,
The problem is I always seem to end up with two of the buggers
axi_interconnect_0 is not there when I start.
When I add a new connection on M_AXI_GP0 then axi_interconnect_0 is created.
Now when I add my ip core axi_interconnect_1 is created, and M_AXI_GP1 is connected to it as well as the new ip core.
Then it all gets very confusing.
AndyC
Users browsing this forum: No registered users and 75 guests
