Parallella Community • View topic - A Beginners Guide to getting started with the Parallella.
Re: A Beginners Guide to getting started with the Parallella
Postby AndyC » Sat Aug 16, 2014 1:58 pm
AndyC
Postby penguin » Thu Aug 28, 2014 8:28 am
penguin
Postby davewr2015 » Sat Aug 29, 2015 9:11 pm
This was a helpful set of examples -- i.e. the series of three posts. Thank you.
I am trying to get the "R" examples running -- so far -- so good. I use R quite a bit for Statistical analysis so comparing it with the AMD 8 core desktops here should be interesting.
BTW: Just don't miss the "configuration lines" -- the exports.... if you download and compile "R".
The configure went fairly quickly -- the MAKE is taking quite a while.
At this point I am testing the headless version and using Putty for SSH -- I will test the monitor version later.
For cooling, I took the side cover off my PC and plugged in an extra fan then set it on the desk blowing over the board. Since I am not running the monitor it seems to run fairly cool.
davewr2015
Users browsing this forum: No registered users and 56 guests
