Parallella Community • View topic - Problems with serial login and possibly booting
Re: Problems with serial login and possibly booting
Postby shodruk » Mon Jun 16, 2014 3:21 pm
Postby timbat » Tue Jun 17, 2014 11:07 pm
Shodruck, thanks, your information was key to me being able to boot my Parallella for the first time.
Disabling the serial console was what it took for me.
timbat
Postby over9000 » Tue Jun 17, 2014 11:32 pm
over9000
Postby shodruk » Wed Jun 18, 2014 8:35 am
Postby greytery » Wed Jun 18, 2014 6:07 pm
Postby shodruk » Wed Jun 18, 2014 6:33 pm
Postby greytery » Wed Jun 18, 2014 11:55 pm
Will follow that network rules advice, thanks very much.
Also, I have not yet checked out the lightweight windows packages tips. I was thinking of adding xrdp to allow remote connection to parallella(s) from Windows 7; better than VNC for what I want. Will continue to play and report back.
Postby fuzz » Fri Jul 04, 2014 2:28 am
So I just got my Parallella board today :D I don't have an OTG cable on hand, so I hooked up a level shifter to the UART pins and installed the headless bitstream and kernel.
Unfortunately it wouldn't give me a login prompt, and found this thread.
I compiled a device tree to change kernel parameters to drop into single user mode, and that gave me a prompt so I could setup static networking to SSH in.
I was playing with upstart scripts as getty wasn't running on the serial port and found that /dev/console is actually tied to /dev/ttyPS0, yet initctl list |grep console shows that it is not started because it would only start when in a container?!?
The baudrate is also set to 38400 in /etc/init/console.conf which matters, so I changed to 115200 and removed "and container CONTAINER=lxc"
After a reboot, I do get the junk characters being sent over (something else likely writing to /dev/console), but now get a working login prompt :)
EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
Freeing unused kernel memory: 188K (c0878000 - c08a7000)
Mount failed for selinuxfs on /sys/fs/selinux: No such file or directory
�Z+����嵽�ѡ����х�ѵɥ����j�����ɽ���*���������ݹ���5Starting fake hwclock: loading system time.(895) terminated with status 1
Fri Jul 4 02:17:47 UTC 2014
* Setting up X socket directories... [ OK ]
Linaro 14.04 linaro-nano console
linaro-nano login:
Looking forward to playing with this board!
fuzz
Postby patwood » Thu Jul 10, 2014 7:09 pm
Looks like auto-serial-console is also running at the same time as the console service. You can disable it by either appending the line
manual
to /etc/init/auto-serial-console.conf or setting ENABLED=0 in /etc/default/autogetty.
patwood
Postby jjg » Tue Jul 15, 2014 12:03 am
I may be experiencing a similar issue (as posted here: http://forums.parallella.org/viewtopic.php?f=50&t=1496)
Do the latest images on this page still have this problem?
http://www.parallella.org/create-sdcard/
- Jason
jjg
